[quote:01e23fe7d5="techman1"]I'm not that up on older car dashboards, but if it has a faceplate ring with 2 holes, you can try gently to use a small pin punch and unthread it counterclockwise. My local automotive electronics supply just had generic panel mount ingition, start, accessory switches on clearance for $3 and I bought one and I don't even need it.[/quote:01e23fe7d5]
The thing is, I already bought a complete lock kit from The Truck Shop..which consist of four new tumblers...(both doors,the ignition, and the glovebox). I have a universal igniton as well..matter of fact its an all brass one...same one I use in my jet-boat...but I would rather keepth OG one. Thanks for your help. I do have the bezel with the two holes. I try it. Thanks.
John
Nov 13, 2006 at 1:18 PM
