2003 Chevy Malibu Key Won't Turn Off
CHEVROLET
NODROG_1985
2003 Chevy Malibu: I started to have problems with my ignition turning to the off position until last night when my key stopped turning all together. Can I replace just the cylinder or do I have to get a whole new ignition and have it programmed by the dealer? Also, could this problem be caused by the cable running from the shifter to the ignition being damaged or streched? If so, please give me a little walkthrough on how to go about repairing that (The reason i believe this might be it is because I have had problems getting the car out of the park position).
Jul 28, 2006 at 1:21 PM
MIKEYBDMAN
  • 623 POSTS
It sounds like it may be your park position switch. Usually there is a small opening on the bottom of your steering column with a tiny cover over it. If you remove this cover, you can insert a small screw driver and manually release the ignition lock solenoid. This should allow you to remove your key until you get it repaired.
If the key release solenoid does not see the shifter in the park position, it will not release the key.
Jul 28, 2006 at 2:04 PM
Suggested Repair
Check the park position switch. If the key-release solenoid does not detect the shifter in Park, it will not release the key. As a temporary override, remove the small cover on the bottom of the steering column and use a small screwdriver to manually release the ignition lock solenoid so the key can be removed until the switch is repaired.
Conversation Summary
The owner of a 2003 Chevy Malibu cannot turn the ignition key to off and asks whether only the lock cylinder can be replaced or a dealer-programmed ignition is required, and whether a damaged or stretched shifter cable could be involved because the car is hard to shift out of Park. The expert says the park position switch is the likely cause: if the key-release solenoid does not see Park, it will not release the key. A small cover under the steering column can be removed so a screwdriver can manually release the solenoid until the switch is repaired.
