2004 Chevrolet Impala Key Won't Turn
CHEVROLET
DECCA
chevy impala 2004 58k
my car had done some thing that i just don't understand the key won't turn and the wheel won't lock. it did this once before for about 2-3 days then one day i came to try it an i started up. but now its been about 3 weeks an i just don't get it
Jan 11, 2007 at 11:53 PM
BRUCE HUNT
  • 3,754 POSTS
There is a switch on the brake assembly in the car under the dash. This is either out of alignment or has failed. Fixing this should restore them both. First, though just to be thorough, check the fuses under the dash AND under the hood.
Nov 1, 2006 at 12:00 AM
Suggested Repair
Check the fuses under the dash and under the hood. Inspect the switch on the brake assembly under the dash; it may be out of alignment or failed. Correcting that switch should restore both key turning and wheel lock.
Conversation Summary
The owner of a 2004 Chevrolet Impala says the key will not turn and the steering wheel will not lock. The same problem occurred once before for a few days and then cleared, but it has now lasted about three weeks. The expert advises checking fuses under the dash and hood and says a brake-assembly switch under the dash is misaligned or failed; fixing it should restore both functions.
