1995 Chevrolet Blazer Popping on Turns
Suggested Repair
Since the ball joints, CV shafts, hubs, and idler arm were already replaced, inspect the remaining steering and suspension bushings, springs, and shock bushings. Briefly spray a penetrating lubricant such as PB Blaster on the bushings; if the pop stops only temporarily, that area is the likely source and the worn bushing or related part should be replaced.
Conversation Summary
The owner of a 1995 4x4 Chevrolet Blazer hears popping when turning the wheel at very slow speed. New CV half shafts, hub assemblies, an idler arm, and upper and lower ball joints did not stop the noise, and two shops could not find the cause. After noting the ball joints were already replaced, the expert advised checking bushings and other steering and suspension parts, using a brief spray of penetrating lubricant to help locate the noise, and also inspecting springs and shock bushings.
