Hi gcaleron, Welcome to 2carpros and TY for the donation
If you haven't check the thermostat do so or just replace it, also might want to check the radiator if its clogged-up feel for cold spots if any possibly its clogged also test the water pump
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
If it continues to overheat try bleeding the system could be airlock-continues to overheat get it block and pressure tested
Tuesday, August 20th, 2019 AT 1:25 PM
(Merged)
