Make SURE it's the pump first. If your sure you will need to drop the fuel tank. Watch out for the fuel lines and the evap lines on the tank, they connect up to a steel line attached to the frame. The pump module is easy to remove once you have the tank out.
SPONSORED LINKS
Thursday, October 2nd, 2008 AT 11:09 PM
