Wont start
RICKY75060
  • 2003 CHEVROLET AVALANCHE
  • V8
  • AWD
  • 102,000 MILES
Every time is cold my truck wont start, battery is good alternator and starter just bought them, and still wont start, I was told is a sensor. It makes the noise that its starts and running well and then it just dies
Saturday, January 5th, 2019 AT 3:25 PM (Merged)
Every time is cold my truck wont start-Check if its fuel or spark problem -do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
