Idles fast when changing gears and has low power
89,700 MILES • V6 • 2WD • MANUAL
MELANIE HERRERA
Had the car fifteen years. It idles really fast and when changing gears it is extremely loud and goes to 3,000 rpm's. It has no get up and go. I am afraid to get on the freeway.
Sep 24, 2018 at 8:46 AM
  • 110,248 POSTS
Please understand, what you described can be the result of several things. The first thing to do is scan the computer. Based on what you said, the check engine light is most likely on all the time. Here is a video that shows how it is done:
https://youtu.be/YV3TRZwer8k
Now, I realize most people don't own a scanner. If that is the case, take it to a parts store and have them scan the computer. Most nationally recognized parts stores will do it for free. Write down the codes that they find.
Once you can get me that information, I will be better able to help. With the present information, it could be related to the fuel system, an engine vacuum leak, a plugged catalytic converter due to the sound change, the ignition system.
I will watch for your reply. If you are unable to have the computer scanned, let me know and I will start walking you through one test at a time. If I give them all to you now, it will be overwhelming.
I will watch for your reply. Feel free to get back to me if you have any questions.
Sep 25, 2018 at 10:40 AM
MELANIE HERRERA
Took my car to a mechanic and discovered I need a new fan clutch. Thank you so much for responding so quickly.
Sep 25, 2018 at 11:27 AM
  • 110,248 POSTS
Happy to help. I am a bit confused. Yes, a locked fan clutch will lead to a noise issue. However, did it fix the high idle too?
Sep 25, 2018 at 12:01 PM
MELANIE HERRERA
It has run great for fifteen years. Suddenly it sounded more like a plane than a car. The idle is good and the noise is gone. He checked out everything since the check engine light was on and said that my car is in great shape.
Sep 26, 2018 at 12:12 AM
  • 110,248 POSTS
That is good news. Take care and let us know if you have questions in the future.
Sep 26, 2018 at 10:29 AM
