3 months ago we replaced the #2 coil. Due to unhooking the battery to fix the radio. it reset the PCM. So after cleaning the throttle body and replacing the coil it ran alot better even a little better.. Well just the other day my fiancé ran outta gas and the truck died. So after all is said and done after jumping it. My car is doing the same exact things it was when the coil was bad.. We went to auto zone to find out what coil is misfiring. 5 codes popped up: P0410/P0014/P0455/P0300/P0526: NO COIL CODE.. We know everything that is popping up all ties together.. But the real question is could it be a coil and its not popping up? And were should we start? Should we just do what we did with the first one? Because all the symptoms are exactly the same.. check engine light blinks on and off the whole time, chugging, sputtering, slow takeoff, low horse power, eating gas like crazy, vibrates when stopping and taking off high RPMs. Reminds me of a older truck the manual dulies.. Makes the same sound. help would be greatly appreciated..
Jan 28, 2016 at 10:53 AM
