Car makes a loud noise when starting
140,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BUSINESSMAN79
I think the value cover gasket and motor mount need to be replaced. I could be wrong.
Feb 26, 2022 at 5:26 AM
SQM
  • 6,383 POSTS
Can you explain a little more of what the noise sounds like?
Here is a helpful guide on engine noises:
https://www.2carpros.com/articles/engine-noises
If you would please upload a video of the startup, this way we have a better understanding of the noise you are heating?
As for having a bad valve cover gasket it won't make any noise. It will leak oil, but noise is not one of the symptoms.
Do you know if you are losing oil?
A bad motor mount can create clunking noise while the vehicle is put on drive or reverse. It can also create vibration.
Feb 26, 2022 at 5:57 AM
