2002 Buick Rendezvous Rear Wiper Blades
2002 BUICK RENDEZVOUS
156,000 MILES • 6 CYL • FWD • AUTOMATIC
DSCKC
The rear wiper blade is not clearing the window. I have found that the blade will lift off the window when in motion. I have tried several different ways to correct this. I have even purchased new blades hoping it will correct this issue. If you have any advice I am open to them.
Feb 6, 2008 at 1:05 AM
MATTI5475
  • 20 POSTS
oil the wiper arm where bolted together. then flip it out
and in a few times. they seem to get stiff in that joint from not being used that much.worked for me on mine, still misses a little bit at the top
Feb 9, 2008 at 2:53 AM
PAULMORGAN
i also bent the arm in a little and flexed the wiper which seemed to work
Sep 29, 2008 at 3:26 PM
