rear window wiper arm
MAMES
How do you remove the rear window wiper arm on a 2002 Rendepoo..vouz? It will not stopp moving and I need to remove it before it scratches up the window. I have removed a nut but it seems to still be firmly attached.
Nov 28, 2007 at 4:48 AM
DENNYP
  • 1,824 POSTS
use a battery terminal puller to remove the arm from the stud.You can pick one up at your local parts store or sears.
Dec 6, 2007 at 12:51 PM
BIGHG
If you can't immediately pull the arm off, you can pull fuse 32 out (center console fuse box) which will stop the arm from moving until you can resolve the problem.
Dec 13, 2008 at 10:02 AM
