2005 Buick Rendezvous Rear wiper arm
2005 BUICK RENDEZVOUS
FORSBERG
2005 Buick Rendezvous 6 cyl Front Wheel Drive Automatic
I bought a new wiper blade. But, it doesn't clean the whole sweep of the blade. More of the middle of the blade is not touching. This is the same reason I bought a new blade. So I didn't remedy anything. I gently bent the wiper arm, that didn't work. I don't want to mess with much more without reassurance. What can I do to correct this problem? Thanks Andrew
Jan 15, 2009 at 7:46 AM
  • 110,240 POSTS
Hi:
There is a spring at the base of the arm (not blade). If it is weak, it won't place enough pressure on the arm to clean. Check if it is rusted, damaged...
Let me know what you find.
Feb 16, 2009 at 10:59 AM
FORSBERG
The spring is not damaged or rusted. I do notice there is not pull when the blade gets closer to the window. Maybe a new spring is in order?
Thanks for the response
Feb 17, 2009 at 3:45 AM
  • 110,240 POSTS
You could try that, but they are a pain to get on. If you have no luck, maybe a new arm will do the trick.
Feb 17, 2009 at 10:41 AM
