1987 Buick Regal Hood Won't Pop
JGBASAR
Vehicle:
Buick Regal Limited Edition
1987
2 Door
Question: My Buick has a very small crack in the oil pan. It leaks only very, very slightly, but it does leak. I haven't been able to put aside enough at once to get it fixed yet, but I have been keeping it filled with oil.
However, recently, the mechanism to pop the hood has ceased working, and the vehicle has been getting lower and lower on oil. I have oil ready and waiting to fill it up, but I can't get the hood open.
Are there any quick ways to pop the hood when the initial catch won't release? If not, how would I go about getting a 1987 Buick Regal's hood catch fixed? (To clarify, it's the initial lever that's not working, not the second release under the hood itself, but the first one, released by pulling a lever on the driver's side floor board.)
Oct 3, 2007 at 12:36 PM
SERVICE WRITER
  • 9,123 POSTS
Unless the cable is bad, you can rap on the hood at the top of the catch area while holding the release and it should pop.
Oct 3, 2007 at 12:51 PM
JGBASAR
[quote:2ef072038e="Service Writer"]Unless the cable is bad, you can rap on the hood at the top of the catch area while holding the release and it should pop.[/quote:2ef072038e]
Thank you very much for your response! Sadly, I've tried that. And if the cable's bad?
Oct 3, 2007 at 11:51 PM
SERVICE WRITER
  • 9,123 POSTS
Without having the car in front of me I can only offer some advice. You can try to get to the cable or mechinism from the bottom, you made need a variety of different basic tools to get to it, to attempt to pull the cable or push the lever it's attached to. Sometimes you get reove things like the grill to gain access.
You can also try a pair of vise grips on the cable at the release handle and pull it in combination with banging on the hood, if the cable is stretched.
Oct 4, 2007 at 1:35 AM
JGBASAR
[quote:b59fd2190f="Service Writer"]Without having the car in front of me I can only offer some advice. You can try to get to the cable or mechinism from the bottom, you made need a variety of different basic tools to get to it, to attempt to pull the cable or push the lever it's attached to. Sometimes you get reove things like the grill to gain access.
You can also try a pair of vise grips on the cable at the release handle and pull it in combination with banging on the hood, if the cable is stretched.[/quote:b59fd2190f]
Thank you very much for all of your advice! I will try all of this.
Oct 4, 2007 at 6:44 AM
Suggested Repair
While holding the hood release, tap the hood over the latch. If that fails, grip the cable at the release handle with vise grips and pull while tapping the hood. If the cable is stretched or broken, reach the cable or latch from below, removing the grille if needed, and pull the cable or push the lever.
Conversation Summary
The owner of a 1987 Buick Regal cannot open the hood because the driver's floorboard release lever does not release the primary latch, so oil cannot be added despite a slight oil-pan leak. The expert suggested tapping the hood over the latch while holding the release. After that failed, the expert advised accessing the cable or mechanism from below, possibly after removing the grille, or using vise grips on a stretched cable at the handle while tapping the hood.
