1981 Buick Regal Dies After Start
JMP210
  • 5 POSTS
i have a 1981 buick regal and in the mornings when i first start up my car, it starts up then dies out, and after i get it going, when i excelerrate it hessitates to go like it wants to churn off but then goes smoothly after that.
Jan 22, 2006 at 3:58 PM
MVANNESSJR
  • 223 POSTS
Check fuel pressure at startup. You may need to replace the fuel pump and/or filter.
Jan 22, 2006 at 11:52 PM
DRILEY16
runs fine untill i go down the street then it die out can anybody tell me why?
Jan 23, 2006 at 9:45 AM
MVANNESSJR
  • 223 POSTS
If fuel pressure checks out fine then the next thing I would look at would be the IAC (Idle Air Control) and throttle body. They may be clogged with carbon deposits and need a good cleaning.
Jan 24, 2006 at 4:55 PM
Suggested Repair
Check fuel pressure at startup and replace the fuel pump and/or filter if pressure is low. If pressure is normal, clean carbon deposits from the idle air control valve and throttle body.
Conversation Summary
A 1981 Buick Regal starts and then dies on cold mornings, hesitates when accelerating, and can die after driving a short distance. The expert advised checking fuel pressure first and replacing the fuel pump or filter if needed. If pressure is fine, the next step is cleaning a carbon-clogged idle air control valve and throttle body.
