1993 Buick Regal Stalls and Dies
BARNESA
I have a 1993 buick regal 3.1v with 200,000 miles. whether idling or at 50 mph the car will attempt to die or stall, but definitly dies at idle intermittently. It doesnt matter if hot or cold, and when it dies the rpm guage sometimes goes up quick then to 0 rpm. It usually starts up again, but lately it cranks over longer untill it starts. If i run up the rpm to 1500 at idle it still wants to stall but i can keep it running longer at a traffic light. There are no ecm codes stored. I replaced: crank sensor, ignition module, spark plugs and wires, iac motor, and all vacuum hoses when i took off the upper plenium to clean it. Maybe its the cam sensor but i cannot find it. I also looked at the rail fuel pressure by barely pressing on the valve you use for testing so a stream would be present and when the car died the stream was the same comming out, so it might not be the fuel pump. Please help,, thanks[/b]
Dec 3, 2006 at 10:50 AM
  • 55,746 POSTS
Sure sounds like a fuel pump, has the car had a new one installed? 200,000 miles is alot of mile for a pump. :D
Dec 3, 2006 at 11:16 AM
BARNESA
[quote:747c35930e="2CarPro Ken"]Sure sounds like a fuel pump, has the car had a new one installed? 200,000 miles is alot of mile for a pump. :D[/quote:747c35930e]
Thanks for the quick responce. No i have not installed a new fuel pump yet, i just never thought it could be the culpret as it dies very quickly like a electronic fault.
Dec 3, 2006 at 11:35 AM
  • 55,746 POSTS
Try it and let me know. Thanks for using the 2carpros.com car repair forum.
Dec 4, 2006 at 5:53 AM
Suggested Repair
Replace the fuel pump. At 200,000 miles, a failing pump can cause intermittent stalling even if a quick visual check of the fuel-rail test port still shows fuel when the engine dies.
Conversation Summary
A 1993 Buick Regal 3.1 with 200,000 miles intermittently stalls at idle and while driving, sometimes with the tachometer jumping before dropping to zero, and it has begun cranking longer before restarting. No ECM codes are stored. The owner replaced the crank sensor, ignition module, spark plugs and wires, IAC motor, and vacuum hoses, and cleaned the upper plenum. A crude fuel-rail check still showed fuel when it died, so the owner suspected an electronic fault such as the cam sensor. The expert attributed the symptoms to a worn fuel pump and recommended replacing it.
