1992 Buick Regal Starts Then Dies
TOM DRISCOLL
When it was above 40 degrees, the car would start and immediately die ,over and over. I had not tried the starting fluid at that time. Could it also be a temp sensor??
Feb 1, 2007 at 12:56 AM
MATHIASO
  • 1,209 POSTS
Temperature sensors are either variable-resistance sensors or on-off-switch sensors.
Temperatur-to-electricity sensor can mesure either engine coolant,air,or surface temperatur as needed.
base on input from the temperatur sensors,the computer can adjust air-and fuel mixture or dump air into the exhaust system to prevent overheating of the catalytic converter.
Now back to the question if the problem could be the temperature sensor.
check the fuel injection system , and still check for a vacuum leak too.
_________________
Feb 1, 2007 at 4:04 AM
Suggested Repair
Check the fuel injection system and inspect for a vacuum leak. A temperature sensor can affect mixture, but the expert did not confirm it as the cause.
Conversation Summary
The owner of a 1992 Buick Regal said the car starts and immediately dies repeatedly when the temperature is above 40 degrees, and asked whether a temperature sensor could be involved. The expert explained how temperature sensors work and advised checking the fuel injection system and looking for a vacuum leak.
