1992 Buick Regal stop running
JASONGOODLOE
Electrical problem
1992 Buick Regal V8 130000 miles
When i crank the car it cranks just fine, i drive to work everyday and its about 5 miles sometimes it works fine but sometimes when I stop at a red light it will just turn off with no warning and when I go try to crand it again it turns over alot but finally after a few punps on the gas pedal it will crank back up what is the problem
Feb 20, 2008 at 1:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:64f24a82b0="jasongoodloe"]Electrical problem
When i crank the car it cranks just fine, i drive to work everyday and its about 5 miles sometimes it works fine but sometimes when I stop at a red light it will just turn off with no warning and when I go try to crand it again it turns over alot but finally after a few punps on the gas pedal it will crank back up what is the problem[/quote:64f24a82b0]
hows the tune up
check fuel pump and pressure
Feb 21, 2008 at 2:12 PM
