1994 Buick Regal Stalls Below 45 MPH
NOMOREBUICKS4ME
I have a 1994 Buick Regal Custom with 74,000 miles on it. (Incidentally, I DO NOT reccomend this model as it has been nothing but trouble.) The latest issue has me stumped. The car performs well enough on the highway, but when I drive at speeds below 45 mph, it stalls at random intervals. Any ideas on why it does this and how to fix it?
Jan 10, 2006 at 9:36 AM
2CARPRO JACK
  • 11,533 POSTS
check the fuel pressure.Could be a Mass Air Flow Meter
Jan 10, 2006 at 9:38 AM
JAMIENOEL
[quote:e95d14a470="nomorebuicks4me"]I have a 1994 Buick Regal Custom with 74,000 miles on it. (Incidentally, I DO NOT reccomend this model as it has been nothing but trouble.) The latest issue has me stumped. The car performs well enough on the highway, but when I drive at speeds below 45 mph, it stalls at random intervals. Any ideas on why it does this and how to fix it?[/quote:e95d14a470]
Mine was doing something like this and it turned out to be a faulty Crankshaft Position Sensor
Oct 21, 2007 at 1:23 PM
JAMIENOEL
I forgot to submit the cause of the problem. It turned out to be a Crankshaft Position Sensor.
It was in bad shape and was cracked. The car has run good ever since.
Aug 23, 2008 at 11:52 AM
Suggested Repair
Check fuel pressure and the mass airflow sensor. A similar low-speed stalling issue was caused by a cracked crankshaft position sensor, so inspect that sensor and replace it if damaged.
Conversation Summary
The owner of a 1994 Buick Regal Custom with 74,000 miles reported random stalling below 45 mph, while highway driving was generally fine. An expert suggested checking fuel pressure and the mass airflow sensor. Another user described a similar problem that was resolved by replacing a cracked crankshaft position sensor, after which the car ran well.
