1994 Buick Regal Buick Regal shuts off while driving.
PAULMOZZI
  • 1994 BUICK REGAL
  • 6 CYL
  • FWD
  • 120,000 MILES
Hi, I am hoping you can help me. While driving my car to work on the highway, it will shut off randomly. I can usually restart it while it is moving, but sometimes I have to pull over and let it sit. It has done this about 5 or 6 times in the last month. Twice it gave me a service engine light with the cam sensor code. I installed a new cam sensor, but I still have the same problem. Could it be the magnet on the cam sprocket? Or possibly an ignition module, coil problem? Any help would be greatly appreciated. Thank you.
Regards, Paul
Wednesday, July 29th, 2009 AT 5:54 PM
DOCFIXIT
  • 18,828 POSTS
Ignition module good choice before you get into parts replacing next time it quits pull over will need a helper. Pull plug wire hold next to block spark? Also spray carb cleaner into intake crank does it fire? Results will help point to problem.
Thursday, July 30th, 2009 AT 8:39 AM
