1989 Buick Regal Dies and Won't Restart
CALLYSTALYNN
I have an '89 Buick Regal with about 100k miles. It is a four door with an automatic transmission. Recently while driving on the road it just stopped. It had a full tank of gas and when I tried to restart it, it refused to start. It wasn't getting gas, so I ended up changing the fuel filter. It ran perfect for almost a full day but then on my way home it died again and refused to restart. What could the problem be?
Jul 15, 2007 at 6:16 PM
CLY
  • 308 POSTS
See if it is temp related....Does it start back up when the motor cools down....Try and pore some water on the cranksensor when the car wont start. I have done this several times to find out if the cranksensor is breaking down hot....
Let me know...
Cly
Jul 17, 2007 at 9:43 AM
Suggested Repair
Check whether the no-start is heat related. After it dies, see if it restarts once the engine cools, and pour water on the crankshaft sensor while it will not start to test whether the sensor is failing when hot.
Conversation Summary
The owner of a 1989 Buick Regal with about 100,000 miles said the car died while driving and would not restart despite a full tank. Replacing the fuel filter restored operation for nearly a day, but it then died again. The expert suggested checking for a temperature-related failure by seeing whether it starts after cooling and pouring water on the crank sensor when it will not start.
