1983 Buick Regal Brakes Not Working
MAVRIK435
I have a 1983 Buick Regal Limited 4.1L V6 with 220,000 miles on it. The Engine runs great but the brakes are not working. I have replaced the Brake master cylinder and the brake booster and the brake pads and shoes. I have also bled the braking system like 10 times, but the brakes still won't work. I am desperate and cannot think of anything else please help me,what might the problem be? and how can I fix it? Please help. Thanks.
Mar 4, 2007 at 1:28 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
are you losing brake fluid? do the calipers work?
Mar 4, 2007 at 5:21 PM
  • 75,988 POSTS
Did you adjust the brake booster pushrod?
Mar 4, 2007 at 5:36 PM
MAVRIK435
No I didn't know I had to ajust the brake booste pushrod, and how do I do that? also how do I check the brake calipers? and no I am not losing brake fluid.
Mar 5, 2007 at 4:26 AM
  • 75,988 POSTS
[quote:cc10729b37="Mavrik435"]No I didn't know I had to ajust the brake booste pushrod, and how do I do that? also how do I check the brake calipers? and no I am not losing brake fluid.[/quote:cc10729b37]
You need a book for the clearance ,follow the brake pedal to the firewall you'll see it there.
Also are you sure your wheel cylinders are not leaking and did you bleed the M/C.
Mar 5, 2007 at 6:12 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
sorry mavrik, meant wheel cylinders (thanks Raz) Long day at work, couldnt think straight, too tired
Mar 5, 2007 at 1:05 PM
Suggested Repair
Adjust the brake booster pushrod to the service-manual clearance at the pedal-to-firewall linkage. Bench-bleed and rebleed the master cylinder, then inspect the wheel cylinders and calipers for leaks or seized operation even if no external fluid loss is obvious.
Conversation Summary
The owner of a 1983 Buick Regal says the brakes still do not work after replacing the master cylinder, booster, pads, and shoes and bleeding the system many times. No brake fluid is being lost. Experts recommend adjusting the booster pushrod to the specified clearance, bleeding the master cylinder, and checking the wheel cylinders and calipers.
