1999 Buick Regal LS Fuel Gauge Inoperative
Suggested Repair
The fuel gauge sending unit is part of the in-tank fuel pump assembly. Drop the tank and replace the assembly, or have a mechanic fit an aftermarket sending unit. Expect about $350 to $500, and bring the vehicle in with only a small amount of fuel.
Conversation Summary
The owner of a 1999 Buick Regal LS says the fuel gauge reads full after startup, then drops to empty, and only briefly registers while driving before returning to full. They ask whether the fault is in the instrument cluster or the tank. The expert says the sending unit is part of the fuel pump assembly in the tank and typically requires dropping the tank for replacement; an aftermarket sender can sometimes be used. Estimated cost is $350 to $500, and the tank should contain only a small amount of fuel for the job.
