speedometer and tachometer
GMC
WIZZERD02
I have a 1986 cutlass salon and recently I had the alternator checked out at auto zone, wherein they require me to rev the engine to 3000 rpm. However, when i rev to 3000 on the tachometer, the autozone machine read only 2000. Which is more likely to be correct, my tachometer or their machine? Also it has seemed that I get passed on the highway a lot even when doing ten over the speed limit, how can I test my speedometer accurately?
Apr 13, 2006 at 11:39 AM
BURRBRIAN
  • 158 POSTS
Do you have an aftermarket tach like a SUN tach or something like that? If you put it in yourself did you check and see if it has a switch for 4-6-8 cyl.? You might have it on 6 cyl. if you are reading that much higher. Just a thought, if it's a factory tach I'm out of ideas. On your speedo have you changed the rear tires to a different size than what the factory put out on it? This will affect your reading. Smaller tires will run speedo faster than you are going- bigger will make it read slower. Hope this gives you something to work with. Good luck. :!:
Apr 14, 2006 at 1:27 AM
WIZZERD02
it has stock tach and speedometer. Tires are factory.
Apr 14, 2006 at 8:29 AM
