1990 Cadillac Fleetwood Fuel Used Off
GMC
TAILFIN
  • 8 POSTS
For every tank or so of gas I use, the "fuel used" indicator on my 1990 Cadillac Fleetwood (Front wheel drive, 4.5 liter V8 ) says I've used somewhere between 1 and 2 gallons less than what fuel I've actually used (takes more at the pump). This has been the case for a couple of years, and I've tried many things and have been unable to phase this problem...
The following things have been replaced at some point during this time, and can be eliminated as they have had no effect on the problem:
Fuel tank and sender unit, fuel filter, fuel pressure regulator, distributor cap, rotor, plugs & wires, alternator, air filter, oxygen sensor.
I also have a receipt from the person I bought the car from which shows the catalytic converter was replaced, so that is doubtful. I have also placed bosch injectors in the car. They were from a salvage yard, but are known to be a superior plug to the stock. In any case, the discrepancy remained unchanged, so even if they aren't perfect, the stability of the problem tends to indicate it as not the problem. I have done a fuel pressure test, and it has acted as it's supposed to with either set of injectors....except that it does slowly bleed down on key off or after the fuel pump is finished with it's 2-second priming when the key is in just the "ON" position before. However, I did try clear flood mode (holding the pedal to the floor before starting and supposedly shutting the fuel off), and it starts every time that way, when it is not supposed to. It will do so immediately though, before any pressure has time to bleed down, so I'm confused as to how fuel could be getting in there other than an overall rich mixture.
There is no visible fuel leak in the lines along the way...and certainly no leak that could account for the sheer amount of fuel in the discrepancy.
There are no diagnostic trouble codes. The oxygen sensor has cross counts in closed loop as it should. The radiator and thermostat have also been replaced, just for reference, though I don't see what they could have to do with it...except that they could have an effect on actual mileage.
The actual mileage is not horrible, but is not what it should be. It is rated for 25 on the highway, and I'm getting maybe 22. If I were getting what the fuel data center thought I was, it would be about right... :?
I know these fuel data centers are capable of being more accurate than this...maybe not on the fuel left in the tank, but on the fuel used, they are. I had an 85 which was a mechanical disaster compared to the 90, but had the same fuel data center and was never off by more than 0.2 gallons. So anyhoo, I'm at a loss for what causes the discrepancy...any help or ideas would be greatly appreciated.
Mar 30, 2006 at 11:30 PM
LOSONE
  • 1,616 POSTS
The fuel used center circuit is a complicated little circuit that is located in the dash. It receives 16V (regulated) from the climate control panel. In addition it receives 5 volts from the ECM. The fuel amount is received from the Body Control Module. All of the these are usually bullet proof.
Before you tear into the dash remove and clean all grounds in the engine compartment. There is a clump of wires attached to the engine block. Some are tan. Insure they are clean and secure. Check the ground from the back of the engine to the body. It MUST be good and connected. The module input grounds (2) are battery ground and not computer grounds.
The two problems I have found in the past were ground problems and a low 16v input from the climate control center.
The last thing would be a defective fuel data center but it could be. I am one for checking all inputs especially the contacts on the fuel daty center. the can be cleaned with a good pencil eraser.
I feel the problem is a dash component problem as I have been there many times.
Good Luck let me know
Mar 31, 2006 at 12:36 AM
Suggested Repair
Clean and secure all engine-compartment grounds, including the wire clump on the engine block and the ground from the rear of the engine to the body. Verify the regulated 16-volt feed from the climate control panel and the 5-volt ECM input, and clean the fuel data center connector contacts. If those inputs are good, suspect a defective fuel data center in the dash.
Conversation Summary
The owner of a 1990 Cadillac Fleetwood reports the fuel-used display reads about 1 to 2 gallons less than fuel actually added at the pump, with slightly low highway mileage and no trouble codes. Many fuel and ignition parts were already replaced without change. The expert says the fuel data center is fed by a regulated 16-volt supply from the climate control panel, 5 volts from the ECM, and fuel data from the body control module, and recommends checking engine grounds and those inputs before replacing the dash unit.
