2000 Chevy Blazer Fuel Gauge Erratic
GMC
AIKVENGER
I have a 2000 Chevy Blazer 4WD with approximately 61K miles. Within the past few weeks whenever I start up, the fuel gauge jumps up to full and then proceeds to bounce around erratically. I have been watching the gauge and it never seems to fall below 1/2 tank even though based on my mileage I should be on Empty. What is wrong and how can I fix it?
May 18, 2006 at 1:17 AM
LSUSSEL
  • 252 POSTS
You need to check the fuel gauge sensor. there may be a short in the fuel line sensor which tells the gauge how much gas you have in the tank. try that and let me know.
- Lee
May 18, 2006 at 5:38 AM
Suggested Repair
Check the fuel gauge sensor for a possible short that could cause the gauge to read incorrectly.
Conversation Summary
The owner of a 2000 Chevy Blazer 4WD with about 61,000 miles reports that the fuel gauge jumps to full at startup, then bounces erratically and never drops below half a tank even when the tank should be empty. The expert advised checking the fuel gauge sensor for a possible short and reporting back.
