1994 Buick Regal Won't start without a boost
DAVE43
  • 1994 BUICK REGAL
  • 6 CYL
  • 260,000 MILES
94 Buick Regal. 3800. Couple days ago worked fine, 15 mins after last drive won't start, just clicking. Replaced battery. Replaced starter/solenoid, negative bat cable. Won't start on own with not even any clicking. Will start no prob with boost(only with another car, charger boost clicks and dash lights go nuts) and continue to run. But won't restart on own. And no clicking now.
Have had charger out and on. Cleaned + connection.
Both batteries have a reading of 12.3-12.5 when tested by themselves but only read 9.6 when connected. Test was done at screw heads. When running test shows 13.9-14.2 v.
Also when trying to start alone not even any idiot lights in dash come on.
Again volt tests were done on head of screw and starts no prob with boost and runs good.
Replaced pos cable and doesn' appear to be it. But without the smaller pos cable connected to the fuse box beside the battery that has the boosting post, the battery tests 12.5 v. And the pos cable to the fuse box on the pass. Side also. Hook up the post cable and reads 9.5 v.
Likely a ground issue? And likely the fuse box beside the battery as it only happens when that's connected?
Unhooked that box from fender wall and don't see any ground and all wires appear to head toward firewall.
With there not being any dash lights or clicking(anymore) when trying to start yet start and run with a boost, does that point to particular fuses that may be grounded.
Any thoughts?
Sunday, June 28th, 2009 AT 4:19 PM
Load test the battery if it won't hold up 9.6 volts in 10secs its no good.
Sunday, June 28th, 2009 AT 6:49 PM
DAVE43
Battery was tested
Monday, June 29th, 2009 AT 7:28 AM
