1997 Buick Park Avenue Coolant Low Warning
SCOUKOULIS
97 Buick Park Avenue Ultra - 90278 miles.
My computer keeps telling me the Engine Coolant is low, but it is not and the car is not overheating. The car is not loosing coolant and this does not seem to be causing a problem.....yet. :roll:
The dealer ran a diagnostic, but could not figure it out. Any help would be appreciated.
Jul 3, 2007 at 3:48 AM
BRUCE HUNT
  • 3,754 POSTS
Have they tested the temperature sensor for the cooling system?
Jul 3, 2007 at 6:28 AM
2CARPRO JACK
  • 11,533 POSTS
Low level sensors go out alot in GM vehicles, it is a simple fix and is most likely in stock at your local dealer." Low Coolant Level Sensor "
Jul 4, 2007 at 12:50 AM
OKHEDHER
  • 6 POSTS
it's right your have to check maybe the coolant is low and u have to carful.see in the morning befor start the ignition when the car is cold fillfit the radiator from it's cap and remove the upper joint that connect the radiatoe with the engin to let the air going out,then fillfit the plastic tank then only by this u can exust the air from engin,omar khedher dubai,u.a.e
Aug 22, 2007 at 11:45 PM
Suggested Repair
Test and likely replace the low coolant level sensor, a common GM failure that is usually available at the dealer. Also have the cooling-system temperature sensor tested.
Conversation Summary
A 1997 Buick Park Avenue Ultra shows a low engine coolant warning even though the coolant level is normal, the engine is not overheating, and no coolant is being lost. A dealer diagnostic did not find the cause. Experts suggested testing the cooling-system temperature sensor and, more specifically, replacing the low coolant level sensor, which commonly fails on GM vehicles. Another reply suggested bleeding air from the cooling system, which does not match the reported symptoms.
