2000 Buick Park Avenue
BIRDDOG446
  • 2000 BUICK PARK AVENUE
Engine Cooling problem
2000 Buick Park Avenue Two Wheel Drive Automatic
Hi. I have a Buick Park Avenue (2000) and lately I've noticed that the temperature gauge needle goes to about the 3/4 mark toward the hot indicator. The weird thing is that this doesn't happen every time I use the car. Sometimes it stays in the middle, or just slightly toward the cool side. The gauge also seems to go down (middle/cool side) when I drive faster on the highway, @ 65-70 mph. In the last month or so, I put new coolant in the reservoir tank, and that seemed to help keep it constant for a couple weeks, but now the needle is going toward 'hot' again, and the tank is full. I know that the car hasn't had a radiator flush for a long time, if ever, and I wondered if that might be what it needs, or if there is a bigger problem? Would you let me know what you think (if this message makes sense). Thanks, Kirk B.
Monday, May 24th, 2010 AT 7:24 PM
  • 109,885 POSTS
Kirk:
If it gets hot in traffic and cools off at highway speed, it sounds like the cooling fans are not turning on. Check them to see if they are working and let me know.
Friday, July 23rd, 2010 AT 11:45 PM
BIRDDOG446
Hi. Sorry it took so long to get back to you. I checked the cooling fans, and they're running ok. Any other advice would be greatly appreciated. Thanks! Kirk
Friday, August 27th, 2010 AT 12:09 PM
  • 109,885 POSTS
If the fans are working and it cools off at highway speed, then the thermostat is working properly. What I would do next is try flushing the cooling system.
Saturday, August 28th, 2010 AT 10:10 AM
