1997 Buick Park Avenue no pressure
RONNIE27SHENAULT
Engine Cooling problem
1997 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 191k miles
my cars radiator doesnt have pressure after the car is running.i think its the water pump,heat doesnt blow out hot only cool.
Apr 14, 2010 at 5:54 PM
  • 75,988 POSTS
Make sure the coolant level is correct start the car up and look inside the radiator opening is the coolant swirling around if not could be the water pump and also check the thermostat
Apr 14, 2010 at 7:11 PM
