1990 Buick LeSabre IAC Motor Location
SPAZ
i have a 1990 buick lesabre with a 3.8 litre v6 where is the idle control control motor located at? and how do i replace it? what is involved?
thank you.
May 6, 2007 at 3:29 AM
JDL
  • 16,098 POSTS
The iac is connected to throttle-body. The air-duct should lead to throttle-body. It's a 4 wire connector at the iac, note the wiring colors. When you get the new part, follow the instructions that come with the part, shouldn't be a problem.
I realize this is an old post. In the future hope you don't have any vehicle issues, but, if you do, keep the site in mind. They are always working to improve the site and it's free to ask a question.
Have a good day.
Jun 15, 2015 at 1:07 AM
Suggested Repair
The idle air control (IAC) motor is mounted on the throttle body, which the air duct leads to. Note the colors on its 4-wire connector, then replace the motor following the instructions supplied with the new part.
Conversation Summary
The owner of a 1990 Buick LeSabre with a 3.8L V6 asked where the idle control motor is located and what replacement involves. The expert said the IAC is connected to the throttle body, identified by following the air duct, and has a 4-wire connector whose wiring colors should be noted. Replacement should follow the instructions that come with the new part.
