2001 LeSabre Fuel Filter Location
GMC
JOSIE373
I have a 2001 LeSabre. Can you tell me where to find the fuel filter? :D
Mar 29, 2006 at 10:14 AM
LOSONE
  • 1,616 POSTS
It is located amid-ships under the car on the drivers side. Insure the car sits for awhile before you change it. It's under pressure and a pain to change unless you are a 3' foot person about 6" thick and without a rack to raise the car. Good luck
Mar 30, 2006 at 12:20 AM
Suggested Repair
The fuel filter is mid-ship under the car on the driver's side. Let the car sit so fuel pressure drops before changing it. Access is tight, so raising the vehicle makes the job easier.
Conversation Summary
The owner of a 2001 LeSabre asked where the fuel filter is located. The expert said it is mid-ship underneath the car on the driver's side and advised letting the car sit before replacement because the fuel system is under pressure. The expert also noted access is cramped without a lift.
