Car will not start?
FPS_DEAN
Sounds like old gas. I second starter fluid, and maybe gas cleaner wouldn't hurt either.
Tuesday, August 4th, 2020 AT 4:38 PM (Merged)
DAVIDRATLIFF
  • 1983 BUICK LESABRE
Engine Mechanical problem
1983 Buick Lesabre 6 cyl Two Wheel Drive Automatic unknow miles
My brother in-law lives 2000 miles away and is having trouble starting his buick. He thinks that it is a 236 V-6 engine. He says it is not firing when it cranks. Does this engine have a coil that may be bad or should he look elsewhere for another problem? He is handicapped with terminal cancer and I am trying to help him solve this problem as quickly and cost effectively as possible.
Thanks,
David Ratliff
Tuesday, August 4th, 2020 AT 4:39 PM (Merged)
He says it is not firing when it cranks. If its cranking over and refuses to start-have someone do below to see if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
