1995 Buick Century no start
YELLOWSKI
  • 1995 BUICK CENTURY
  • 4 CYL
  • 100 MILES
I have replaced coil packs, icm, ecm, crankshaft sensor with new parts, engine will run fine for a few days and then it seems on cold wet mornings it will not start and checking the plugs it appears 2 and 3 are not firing, take back to the shop and we repeat the whole exercise I am on about the 6th time
Monday, March 29th, 2010 AT 10:42 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation, not sure what I could do that the shop didn't? Start the vehicle, let it idle, use a spray bottle with water, spray ignition components, see if you can get a reaction. The autostore may have some water proofing spray, follow the directions on the container. There is also, dielectric grease, supposed electrical circuits from shorting.
Wednesday, March 31st, 2010 AT 2:58 PM
YELLOWSKI
I did as you suggested and I believe the problem being the new spark plug cables, I replaced were defective, when I sprayed them the engine began to sputter, I replaced them sprayed with water and so far ok
thanx
Thursday, April 1st, 2010 AT 8:16 PM
2 LINSEY
  • 287 POSTS
Hi yellowski,
We're glad to see you have resolved your problem with your buick. Thank you for using 2CarPros. Com. We appreciate your donation and look forward to helping you in the future.
Monday, April 5th, 2010 AT 12:11 PM
