This car was running fine, then it started to rattle, for lack of a better word (as per my daughter). The car cut off, and has not ran since. I had the car towed and discovered it has no fuel pressure at the regulator and it has no spark on any cylinder. When the key is turned on, I can here the two second pump cycle, but no fuel or spark. Does the lack of fuel prohibit the ignition? Perhaps an ECM problem? Just too many possibilities just to throw expensive parts at! Thanks! David
Nov 22, 2016 at 1:19 AM
