Engine Performance problem
1995 Buick Century 6 cyl Front Wheel Drive Automatic
My 95 century won't start, this is the first time this has happened. Tempature outside is 25. Battery has a full charge.
Sunday, February 7th, 2010 AT 9:55 AM
JDL
MECHANIC
Welcome to the forum. If it cranks good but won't start, have a helper crank it while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Can you check for trouble codes?
