HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Century
Engine
Symptoms
Not Running
1994 Buick Century won't start
CONKRITEJON
MEMBER
1994 BUICK CENTURY
6 CYL
2WD
AUTOMATIC
189,000 MILES
Have 3.1 v-6, just rebuilt heads. Blew a head gasket- water in oil. Back together just won't start? What can I do?
Monday, February 22nd, 2010 AT 10:03 PM
MECHANIC
Did you position piston no.1 on its compression stroke/TDC and align cam and crank markings correctly-
Also are you getting the corrrect fuel pressure and a snapping blue spark?
Monday, January 14th, 2019 AT 9:41 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1994 Buick Century Starting Problem
I Got A 94 Buick Century And The Engine Turns Over But It Just Wont Start
Asked by
edwcul
1 ANSWER
1994
BUICK CENTURY
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1994 Buick Century
I Have Owned This Vehicle For A 1.5 Years And Wanted Ac.I Recently Recharged A Completely Empty Low Valve And The A/c Compressor Engaged...
Asked by
xfrostbitex
1 ANSWER
1994
BUICK CENTURY
1994 Buick Century Car Will Not Start
Engine Will Not Start, Replaced Plugs Wires Air, Fuel Filter, And Fuel Pump. Could It Be A Timing Problem And Could Jumping Timing Cause...
Asked by
drkeister
1 ANSWER
1994
BUICK CENTURY
1994 Buick Century It Stalled And Wont Start Back Up
I Have A 1994 Buick Centry And 2day For Some Reason It Stalled When I Was Driving It And Wont Start Back Up It Has Gas And The Fuel Pump Is...
Asked by
pjwk146
1 ANSWER
1994
BUICK CENTURY
Why Will Not Start
1994 Buick Century Will Not Start After Battery Shorted On Manifold. Prior To This Ac Compressor Pully Froze, Removed Compressor Replaced...
Asked by
jjjohnt31313
1 ANSWER
1994
BUICK CENTURY
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
