1994 Buick Century Starting problem
EDWCUL
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 19,655 MILES
I got a 94 buick century and the engine turns over but it just wont start
Wednesday, March 26th, 2008 AT 10:14 PM
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump and listen to the injector/s are they pulsing.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself, distributor pick-up, control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Monday, January 14th, 2019 AT 9:41 AM
