1994 Buick Century it stalled and wont start back up
PJWK146
  • 1994 BUICK CENTURY
  • 4 CYL
  • FWD
  • 130,000 MILES
I have a 1994 buick centry and 2day for some reason it stalled when I was driving it and wont start back up it has gas and the fuel pump is working and when u try to start it it sounds like it has no gas it wants 2 start but wont can u tell me what the problem might be please cuz I put new plugs in and cant figure out and I dont have alot of money 2 mess with
Friday, September 17th, 2010 AT 10:54 PM
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, January 14th, 2019 AT 9:41 AM
