1994 Buick Century car will not start
DRKEISTER
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 200,000 MILES
Engine will not start, replaced plugs wires air, fuel filter, and fuel pump. Could it be a timing problem and could jumping timing cause internal damage?
Saturday, February 14th, 2009 AT 3:35 PM
Do below to determine if its fuel or spark issue
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, January 14th, 2019 AT 9:41 AM
