1991 Buick Century LOSS OF FUEL DELIVERY - DIES IN FLIGHT
FORDDADDY
  • 12 POSTS
Fine, just needed to be sure I was fully inderstanding the method. I've obtained the niod lite and will check this tonite.
To summarize, if car is in failure mode, and the tickle produces a blinking noid lite, then we have eliminated the ignition module under the coils, correct?
If this happens, do I then buy the computer, or do another test?
If no noid lite response with the tickle, do I then buy the ignition module?
Thanks.
Monday, August 24th, 2009 AT 4:48 PM
JDL
  • 16,098 POSTS
If the noid lite flashes, I would suspect the ignition module. If the noid lite doesn't flash, I'd have to check the circuits to and from the computer, as well as the computer.
Tuesday, August 25th, 2009 AT 9:17 AM
