1991 Buick Century Fuel Delivery
DRGGNSUZU
Engine Mechanical problem
1991 Buick Century 6 cyl Front Wheel Drive Automatic
Car Was Not Getting Any Gas Did not Hear Fuel Pummp Coming On. Disconnected Line From Filter To Motor No Fuel Coming Out. Replaced fuel pump put car back together still no fuel delivery no sound pump is coming on does car have a fuelpump reset switch and if so where is it or where is a fusible link, fuse, or circuit breaker for the pump.
Sep 6, 2009 at 2:03 AM
JDL
  • 16,098 POSTS
Check the ecm/fuel pump fuse, should be located under the hood, passenger side front, close to the relay pack. The fuel pump relay is in the relay pack, closest relay to the radiator. When in doubt, which relay is which, look at the wire colors at the connector, match with wirng diagram. Right now, I don't believe the relay is faulty, but you can check the circuits.
Also there should be a fuel pump prime connector, under the hood, It's just a test circuit for the pump. Should be located, driverside firewall, between the master cylinder and fender. Red wire with electrical connector, nothing plugged into it. If you use a jumper wire from the + bat terminal to connector, the pump should run. You don't need to use the ignition key. Use an inline fuse on the jumper.
Sep 6, 2009 at 3:04 AM
