Anti-Theft System plus oddities?
DSCHWINDT
  • 21 POSTS
Pin 12 on the CCRM is supposed to have power when the key is on but it does not. Pin 12 does come from the PCM, so I took off the PCM to test the wire that runs to pin 12. This wire showed connectivity and less than one ohm of resistance. So, pin 12 should be getting power from the PCM, but it is not. I can check later if the noise goes away when the PCM is disconnected.
Saturday, October 26th, 2024 AT 11:30 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
That would be great that way we can know if something is shorted like an injector or ignition coil.
Sunday, October 27th, 2024 AT 11:10 AM
DSCHWINDT
  • 21 POSTS
So, I tested the car with and without the PCM tonight, and with the PCM all the issues are the same as they've been. Once I disconnected the PCM, there was a sound coming from the engine bay that sounded like fans turning on, but the CCRM made no noise at all.
Monday, October 28th, 2024 AT 5:14 PM
KEN L
  • 47,643 POSTS
So the CCRM stopped making noise with the PCM disconnected?
Tuesday, October 29th, 2024 AT 10:58 AM
DSCHWINDT
  • 21 POSTS
Correct. The CCRM only makes noise when the PCM is connected, and I turn the key to the ON position.
Tuesday, October 29th, 2024 AT 11:33 AM
DSCHWINDT
  • 21 POSTS
I am confused why the CCRM would be buzzing/vibrating if an injector or fuel pump is grounded. Is that possible?
Tuesday, October 29th, 2024 AT 3:35 PM
DSCHWINDT
  • 21 POSTS
Any thoughts?
Saturday, November 2nd, 2024 AT 3:45 PM
KEN L
  • 47,643 POSTS
Yes, when the CCRM is buzzing start disconnect sensors, fuel injectors, the fuel pump and coils until the noise stops and then you have found the problem.
Sunday, November 3rd, 2024 AT 11:14 AM
DSCHWINDT
  • 21 POSTS
Okay. I turned the key, the CCRM began buzzing, and I was about to disconnect a fuel injector, and then I heard a click and the buzzing stopped. I then tried to turn on the car and it fired right up. This is a recurring theme where the problem is intermittent, and then I can't troubleshoot because the problem isn't manifesting itself. Just informing you in case this helps isolate the problem, but I will try to get the problem to reoccur so I can troubleshoot.
Tuesday, November 5th, 2024 AT 3:32 PM
DSCHWINDT
  • 21 POSTS
Alright, I got the CCRM buzzing again. I unplugged the fuel pump fuse, and the buzzing remained. Is that sufficient for 'disconnecting the fuel pump' or do I need to do something else? Also, it seems like the fuel injectors are inaccessible without taking apart some of the engine. Does that sound correct? I also disconnected some sensors, but I don't know all the sensors I may need to check.
Wednesday, November 6th, 2024 AT 3:42 PM
KEN L
  • 47,643 POSTS
Yes, we need to keep unplugging sensor like the oxygens sensor and ignition coils with the key on until the buzzing stops.
Thursday, November 7th, 2024 AT 5:22 PM
