Anti-theft mode?
50,000 MILES • 4 CYL • TURBO • 4WD
CTARMENTA60
I went out to the vehicle first thing in the morning and the car was dead. Key FOB wouldn't unlock the doors, so I unlocked the car with the high security key inside the key FOB. I hooked up the jumper and the alarm went off. I then noticed the negative cable from the battery to the body was very loose, so I tightened it. The battery was at about 4 volts. I took the battery out and had it charged. Reinstalled the battery and when I get in the car with the key FOB and try pushing the brakes then the start button the alarm goes off. The display says "place key in backup position". I tried putting the key FOB in every backup position I could find on the internet as well as on the steering column, but nothing works.
Sep 20, 2023 at 1:55 AM
  • 55,721 POSTS
Yep, it sounds like the battery needs to be replaced not just charged, but to be sure let's check the surface voltage of the battery which should be about 12.4 volts.
This guide can help:
or this guide:
Please go over these guides and get back to us.
Sep 21, 2023 at 5:41 AM
