I replaced my lithium battery in my key chain lock and it will not program as per instructions in my manual. Prior to that my alarm system would go off whenever I would open the door and would not shut off for several minutes. I took out the fuse for the horn and disconnected the car battery to reset the computer but the problem still persisted. Also, prior to all of this the battery light stayed on for several minutes then shut off and came back on from time to time. I had the battery checked and alternator checked which both turned out to be okay. The battery light still stays on after several minutes of driving. Would these problems happen to all be interconnected? If so, in your professional opinion what do you think the problem is? Thank you.
Aug 25, 2009 at 12:03 PM
