Ford Escape 2002 after market alarm
DORU
I recently purchased a after market alarm system with remote start plc2 way. It was installed by a professional company. I had to pay separately for the unit and also installation, bypass sensor and key copy. Here is the big problem: Everything works good except remote start. I took the car back to the company what installed the alarm, they reset the bypass sensor, remote start works but in about 6 hours won't work again. Same story, take it back, reset the bypass, works, 6 hours later, it doesn't. I believe that anti-tefth kicks in and won't allow me to start the engine remotely.
I took it back again, being really fustrated and it happened again - in about 6 hours after reset, remote start won't work. Company who installed the system won't do anything to fix it and they keep saying that installation is correct but ...
Anyone who can explain and/or help to solve this issue? There is a problem with the system, bypass sensor, anti-tefth or installation? Any help will be greatly appreciated.
Oct 23, 2007 at 1:57 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the factory alarm is winning the battle with the aftermarket one. Personally I would remaove all the aftermarket alarm and use the factory one.It is engineered into the vehicle.
Oct 23, 2007 at 8:50 AM
DORU
Thank you, and yes, aftermarket fails vs oem. I actually need the remote start (I live in Ohio - I get at least 4 months of winter)
Oct 23, 2007 at 9:39 AM
2CARPRO JACK
  • 11,533 POSTS
I realize they can be convenient, but I personally dont like aftermarket electronics that can interfere with my truck starting
Oct 23, 2007 at 10:31 AM
