Alarm system
144,000 MILES
KIMBERLY BROWN
I lost my one key fob and now it takes up to four minutes for blinking lights to stop. i had to remove fuse for horn. It kills my battery and tried to set a new fob with Ford code to no avail. Please help before i scrap my vehicle.
Apr 30, 2017 at 11:23 AM
  • 55,851 POSTS
Here is the procedure for reprogramming the FOB
Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Cheers, Ken
May 3, 2017 at 3:20 AM
