1997 Acura TL
DPICKENS
  • 1997 ACURA TL
  • 6 CYL
  • FWD
  • 152,000 MILES
First of all I would like to say thaks for the reply back. How can I tell if it is circulating properly? Do this sounds like blown head gaskets. Acura said it is not leaking and the water pump is not leaking this does not neccesarry means that the water pump is not bad?
Monday, January 14th, 2008 AT 1:29 PM
  • 31,937 POSTS
Hi there,
To check if the heater is circulating, warm up engine, turn heater to high, while engine is running feel both heater hoses, they should both be hot to touch, if one hot and the other not, heater tap or controller may be faulty, check this first.
Mark (mhpautos)
Tuesday, January 15th, 2008 AT 2:21 AM
