Will not start/run after it warms up
JERAMY HANNER
Yes sir. I've done everything in this thread now. Just got back from my drive and it stalled once but started right back up. Then parked it let it sit for 1 minute then tried starting it again and it started (before the temp sensor it would not start back up). Note: I also put a 180° thermostat in and it calls for 195° but since the problem only occurs at higher temperatures I figured it would help out.
Saturday, March 14th, 2020 AT 3:10 PM
  • 52,797 POSTS
No, you need a 195. If the engine runs at 180, the fuel mapping will be off. It will run rich as the ECM needs to see 195 for it to give the correct commands for fuel mapping.
Saturday, March 14th, 2020 AT 3:16 PM
JERAMY HANNER
I know you know what your talking about. I completely agree with you. That being said this car has had everything you can think of tested and checked. (Fuel pressure, spark, voltage of almost everything possible). The only sensor that was not changed was the temp sensor. No one ever thought of it because it never overheated. If this fixes the issue I will definitely throw a 195 thermastat in it. But for now the cooler the better.
Saturday, March 14th, 2020 AT 3:23 PM
  • 52,797 POSTS
Okay, got it.
Keep us updated.
Saturday, March 14th, 2020 AT 3:24 PM
