No start
STANLEY76
  • 28 POSTS
I do not have a security system or a key with a chip. Is there some kind of security I do not know about?
Thursday, June 21st, 2018 AT 1:41 PM (Merged)
HMAC300
  • 48,601 POSTS
All vehicles have security/anti-theft on them since the 1990's regardless whether the dealer tried to sell you a system or not. These come from the factory like that. I know you have been messing around with this for at least three weeks or so. Have a pro scan it with his scanner he will tell you right away you do not need to go to a dealer. Thanks for using 2CarPros. Com.
CHUCK3132003
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 100,000 MILES
My truck occasionally will not start until the second or third key turnover, is this a problem with the fuel filter or regulator?
  • 109,885 POSTS
It could be either. What you need to do is check the pressure and fuel pressure drop off. It could be loosing its prime causing the problem. Here is a how to for checking the pump, regulator, and drop off. You will need a gauge, but most parts stores will lend or rent them.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
joe
RHOULE
  • 2005 DODGE RAM
  • 5.7L
  • V8
  • 360,000 MILES
It cranks but does not start.
CARADIODOC
  • 33,916 POSTS
That is a lot of information to wade through. How about a clue as to what you have checked already? Do you have spark? Is the fuel pump running? Check engine light on? Is the gas tank empty?
SNAVRATIL
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 60,000 MILES
After sitting over night truck starts fine. After running truck if truck sits more then ten minutes will not start unless accelerator is pressed. When it starts seems like engine is flooded and can smell fuel.
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating.
Is the check engine light coming on in dash? If so pull codes and post them for me. If not than make sure check engine light bulb is not burnt. If it is not burnt and not coming on but vehicle is running poorly this often indicates a faulty computer.
SNAVRATIL
Check engine light does not come on. Bulb has been checked. Engine runs great except for this start up problem.
BLUELIGHTNIN6
  • 16,542 POSTS
Hard start warm engines are most commonly caused by a dirty fuel filter or failing fuel pump. It can, however, be a faulty EVAP component but this will cause the engine light to appear. Replace the fuel filter and see if the problem still exists.
RENEE BUTLER JOHNSTON
  • 2005 DODGE RAM
  • 4.7L
  • V8
  • 200,000 MILES
I replaced the engine in my truck (1500), the engine was running before removal to install in my truck. Now it will not start. I am getting fuel, but no spark, it just spins over. Could it be the timing chain? I have replaced all sensors, ignition switch and ignition switch module located in the steering column. Everything, lol! I am really not wanting to tear it apart, but it is looking like that is the issue. It spins over great just no start.
HALREAMES
  • 2005 DODGE RAM
  • 5.7L
  • V8
  • 4WD
  • 68,000 MILES
I went to start my truck and when I turn the key it just goes click. I checked battery voltage and it said 12.21 volts. I put a jump on it and it cranks right over. Once in a while it will turn over and start. Checked alternator and it shows good. Put a charge on the battery and it says fully charged turn the key and click. Put it on jump and it cranks right over. Starter solenoid?
JOHNNYT73
  • 924 POSTS
Check your battery connections to make sure they are clean and tight. Inspect the battery cables for corrosion all the way to the starter and your ground connections. Make sure cable n starter is tight as well. Could also just be a failing starter.
HALREAMES
Thanks for the information. I had the battery rechecked and as I suspected it was bad. Once you put a load on it the voltage dropped. Thanks for the quick response.
KAJO02
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 54,234 MILES
Truck will turn over but will not start. We took a fuse out and the truck worked for six months but today it stopped working. We checked the battery and the alternator. Any ideas?
JDL
  • 16,098 POSTS
Are the cranking rpms okay? Can you check for codes?
Can you do some of the basic tests? Have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, check fuel pressure.
Do you think the theft system might be causing a problem?
KAJO02
We had to disconnect the theft system because it keep going off. When we pulled that fuse the truck turned over but now something is draining the battery and it would not turn over even though the anti theft system is not connected. We thought it might be that but do not know how to fix it.
Thursday, June 21st, 2018 AT 1:42 PM (Merged)
BEN P
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 84,000 MILES
I was driving slow in a deep puddle and waked by another vehicle truck stalled out water rising has now covered the floor up to the pedals. What type of damage am I looking at? I have not tried to start it and no water has reached any of the electrical system.
RONSON
  • 77 POSTS
  • 2005 DODGE RAM
  • 5.9L
  • V8
  • RWD
  • 65,000 MILES
On my truck (1500) I seem to be getting a flat spot in the acceleration that seems to be getting a little worse over the past week. When you depress the gas pedal from a stop it starts off then there is no acceleration for a short range through depressing the pedal then it jumps abruptly and goes. Can you tell me what this may be? Maybe a throttle position sensor?
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge.
Here is a link that will be a great help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the code number(s) please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
